Sony Bloggie 3D Player Main Button's Circuit Board Replacement
  1. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Front Cover: step 1, image 1 of 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Main Button's Circuit Board Replacement: step 2, image 1 of 2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: step 3, image 1 of 2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Detach the board from the ZIF connector using a pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector on the backside. Now you can safely remove the circuit board.
Robert Tam
6 Reputation
2 Guides authored
Cal Poly, Team 7-12, Maness Winter 2013 Member of Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 378
