Sony Alpha NEX-3N Shutter Replacement
  1. Sony Alpha NEX-3N Shutter Replacement, Getting Started: step 1, image 1 of 2 Sony Alpha NEX-3N Shutter Replacement, Getting Started: step 1, image 2 of 2
    • Remove battery and card
  2. Sony Alpha NEX-3N Shutter Replacement, Back Case 1: step 2, image 1 of 3 Sony Alpha NEX-3N Shutter Replacement, Back Case 1: step 2, image 2 of 3 Sony Alpha NEX-3N Shutter Replacement, Back Case 1: step 2, image 3 of 3
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N Shutter Replacement, Back Case 2: step 3, image 1 of 1
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N Shutter Replacement, Back Case 3: step 4, image 1 of 3 Sony Alpha NEX-3N Shutter Replacement, Back Case 3: step 4, image 2 of 3 Sony Alpha NEX-3N Shutter Replacement, Back Case 3: step 4, image 3 of 3
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N Shutter Replacement, LCD assembly: step 5, image 1 of 2 Sony Alpha NEX-3N Shutter Replacement, LCD assembly: step 5, image 2 of 2
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N Shutter Replacement, LCD Assembly: step 6, image 1 of 3 Sony Alpha NEX-3N Shutter Replacement, LCD Assembly: step 6, image 2 of 3 Sony Alpha NEX-3N Shutter Replacement, LCD Assembly: step 6, image 3 of 3
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N Shutter Replacement, The LCD assembly: step 7, image 1 of 1
    • The LCD assembly
  8. Sony Alpha NEX-3N Shutter Replacement, Keypad: step 8, image 1 of 3 Sony Alpha NEX-3N Shutter Replacement, Keypad: step 8, image 2 of 3 Sony Alpha NEX-3N Shutter Replacement, Keypad: step 8, image 3 of 3
    • Lift the keypad.
    • Detach FPC
  9. Sony Alpha NEX-3N Shutter Replacement, Screws: step 9, image 1 of 1
    • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
  10. Sony Alpha NEX-3N Shutter Replacement: step 10, image 1 of 2 Sony Alpha NEX-3N Shutter Replacement: step 10, image 2 of 2
    • Slide the flash assembly backwards with caution.
    • Detach flash FPC by pulling it out of the socket.
    • High Voltage! Do NOT touch metal on FPC.
    • Then remove the flash assembly.
  11. Sony Alpha NEX-3N Shutter Replacement: step 11, image 1 of 1
    • Remove that part whatever called, by sliding it backwards.
  12. Sony Alpha NEX-3N Shutter Replacement, Screws: step 12, image 1 of 3 Sony Alpha NEX-3N Shutter Replacement, Screws: step 12, image 2 of 3 Sony Alpha NEX-3N Shutter Replacement, Screws: step 12, image 3 of 3
    • 1 ST1.7x5
    • 2 ST1.7x5
    • 1 M1.4x3.6 black
  13. Sony Alpha NEX-3N Shutter Replacement, The Grip: step 13, image 1 of 2 Sony Alpha NEX-3N Shutter Replacement, The Grip: step 13, image 2 of 2
    • Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
    • Pop the grip off. From back, push to the right, then it flies forward.
  14. Sony Alpha NEX-3N Shutter Replacement, More Screws: step 14, image 1 of 1
    • Remove 2 M1.4x2 black screws
  15. Sony Alpha NEX-3N Shutter Replacement, Pop the Shielding Cover: step 15, image 1 of 2 Sony Alpha NEX-3N Shutter Replacement, Pop the Shielding Cover: step 15, image 2 of 2
    • with caution and patient.
  16. Sony Alpha NEX-3N Shutter Replacement, One More Shield: step 16, image 1 of 3 Sony Alpha NEX-3N Shutter Replacement, One More Shield: step 16, image 2 of 3 Sony Alpha NEX-3N Shutter Replacement, One More Shield: step 16, image 3 of 3
    • 1 M1.4x3.6
  17. Sony Alpha NEX-3N Shutter Replacement, Detach 7000 FPCs: step 17, image 1 of 1
    • Sensor power, flip
    • Sensor signal, flip
    • Shutter, pull
    • Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
    • Whatever, pull
    • Whatever, pull
    • Shutter charger motor FPC, (backside, pull out)
  18. Sony Alpha NEX-3N Shutter Replacement: step 18, image 1 of 1
    • Flip the Mainboard up
    • Pull out one more FPC
    • Discharge then desolder 4 wires.
    • CAUTION! Possible high DC voltage >300V
  19. Sony Alpha NEX-3N Shutter Replacement: step 19, image 1 of 1
    • Lift main board and plastic frame with flash capacitor.
  20. Sony Alpha NEX-3N Shutter Replacement, FPC cables: step 20, image 1 of 1
    • Detach sensor Power (L)and Signal(R) FPC
  21. Sony Alpha NEX-3N Shutter Replacement, Screws: step 21, image 1 of 1
    • Remove 3-4 ST1.7x5 screws
    • Remove 1 M1.4x5 screw
  22. Sony Alpha NEX-3N Shutter Replacement: step 22, image 1 of 2 Sony Alpha NEX-3N Shutter Replacement: step 22, image 2 of 2
    • Remove 4 ST1.7x5 screws for the E-Mount
    • Remove mount metal ring
  23. Sony Alpha NEX-3N Shutter Replacement, E-Mount: step 23, image 1 of 3 Sony Alpha NEX-3N Shutter Replacement, E-Mount: step 23, image 2 of 3 Sony Alpha NEX-3N Shutter Replacement, E-Mount: step 23, image 3 of 3
    • Remove mount plastic ring
    • remove mount spring ring
  24. Sony Alpha NEX-3N Shutter Replacement, Sensor + Shutter: step 24, image 1 of 1
    • Sensor + Shutter assembly comes off
  25. Sony Alpha NEX-3N Shutter Replacement, Sensor Frame: step 25, image 1 of 1
    • Separate sensor + shutter from another frame
  26. Sony Alpha NEX-3N Shutter Replacement, The Sensor: step 26, image 1 of 3 Sony Alpha NEX-3N Shutter Replacement, The Sensor: step 26, image 2 of 3 Sony Alpha NEX-3N Shutter Replacement, The Sensor: step 26, image 3 of 3
    • Remove 3 ST1.7x5 screws
    • Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
  27. Sony Alpha NEX-3N Shutter Replacement, Shutter: step 27, image 1 of 2 Sony Alpha NEX-3N Shutter Replacement, Shutter: step 27, image 2 of 2
    • Remove sensor. the shutter assembly comes off.
    • Careful with 3 tiny spacers. Do NOT lose them.
  28. Sony Alpha NEX-3N Shutter Replacement: step 28, image 1 of 1
    • Separate Shutter assembly form the mount body.
  29. Sony Alpha NEX-3N Shutter Replacement: step 29, image 1 of 3 Sony Alpha NEX-3N Shutter Replacement: step 29, image 2 of 3 Sony Alpha NEX-3N Shutter Replacement: step 29, image 3 of 3
    • Remove 1 screw (from the "Front" side)
    • Separate shutter curtain (Photo 3) from charging motor (not shown).
Terrance
6,368 Reputation
17 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 36
All Time: 463
