Solio Bolt Battery Holder Replacement
  1. Solio Bolt Battery Holder Replacement, Remove Screw: step 1, image 1 of 1
    • Open the solar panel of the Solio Bolt. Using a philips screwdriver, remove the screw.
  2. Solio Bolt Battery Holder Replacement, Open Case: step 2, image 1 of 1
    • Use a plastic spudger to pry apart the case.
  3. Solio Bolt Battery Holder Replacement, Remove The 'Battery Holder' Assembly: step 3, image 1 of 2 Solio Bolt Battery Holder Replacement, Remove The 'Battery Holder' Assembly: step 3, image 2 of 2
    • Use a philips screwdriver to remove the three screws securing the battery cradle to the device case.
Ethel
324 Reputation
3 Guides authored
UMass Dartmouth, Team 1-3, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-3, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G3
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 135
