Slingbox SOLO Motherboard Replacement
  1. Slingbox SOLO Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. Slingbox SOLO Motherboard Replacement: step 2, image 1 of 3 Slingbox SOLO Motherboard Replacement: step 2, image 2 of 3 Slingbox SOLO Motherboard Replacement: step 2, image 3 of 3
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. Slingbox SOLO Motherboard Replacement: step 3, image 1 of 3 Slingbox SOLO Motherboard Replacement: step 3, image 2 of 3 Slingbox SOLO Motherboard Replacement: step 3, image 3 of 3
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
Nitin Muralidhar
222 Reputation
2 Guides authored
IUPUI, Team 2-2, Harley SU 2016 Member of IUPUI, Team 2-2, Harley SU 2016
IUPUI-HARLEY-SU16S2G2
5 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 564
