Sliding Folding Door Hinge Replacement
  1. Sliding Folding Door Hinge Replacement, Hinge: step 1, image 1 of 1
    • Using the Phillips #2 screwdriver, remove any remaining old screws and hinges that you want to replace.
    • Counterclockwise will remove the screws.
  2. Sliding Folding Door Hinge Replacement: step 2, image 1 of 1
    • Screws come loose when the holes become too large for the screws. If necessary, drill new holes into the door.
    • In this case, the top two holes were no longer usable, so we created more underneath the bottom holes.
  3. Sliding Folding Door Hinge Replacement: step 3, image 1 of 2 Sliding Folding Door Hinge Replacement: step 3, image 2 of 2
    • One by one, use the screwdriver to place the new screws.
    • The screws shouldn't be too tight. Be sure that the hinge is loose enough to rotate while placing the other screws.
    • Tighten all screws best you can with the hand held screwdriver.
  4. Sliding Folding Door Hinge Replacement: step 4, image 1 of 1
    • The new hinge and screws should be in place now. If you would like, you can patch up the old holes and paint over them.
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 667
