Skytex SP728 Speakers Replacement
  1. Skytex SP728 Speakers Replacement, Case: step 1, image 1 of 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Speakers Replacement: step 2, image 1 of 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Speakers Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Speakers Replacement: step 4, image 1 of 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Speakers Replacement, Speakers: step 5, image 1 of 1
    • Identify the connection location of the wires from the speakers.
  6. Skytex SP728 Speakers Replacement: step 6, image 1 of 1
    • Use a soldering iron to remove the speaker wires from the circuit board
  7. Skytex SP728 Speakers Replacement: step 7, image 1 of 1
    • Solder the new speakers to the correct location, making sure the red wire goes to the + and the black wire goes to the -.
Chris Nelson
213 Reputation
2 Guides authored
USF Tampa, Team 5-1, Brown Winter 2015 Member of USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 108
