Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: step 1, image 1 of 2 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: step 1, image 2 of 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: step 2, image 1 of 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: step 2, image 2 of 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: step 2, image 3 of 3
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: step 3, image 1 of 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: step 3, image 2 of 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: step 3, image 3 of 3
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: step 4, image 1 of 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: step 4, image 2 of 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: step 4, image 3 of 3
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
Joshua Morrison
196 Reputation
2 Guides authored
Cal Poly, Team S19-G3, White Winter 2019 Member of Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Members
12 Guides authored
One Comment
What is the motor PN and where can I get one?
Dennis Meece - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,469
