Shark Rocket Powerhead AH401 Panel Screws Replacement
  1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: step 1, image 1 of 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: step 1, image 2 of 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: step 1, image 3 of 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Panel Screws Replacement: step 2, image 1 of 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: step 2, image 2 of 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: step 3, image 1 of 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: step 3, image 2 of 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: step 3, image 3 of 3
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Panel Screws Replacement: step 4, image 1 of 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: step 4, image 2 of 2
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: step 5, image 1 of 2 Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: step 5, image 2 of 2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
Toan Pham
269 Reputation
3 Guides authored
Cal Poly, Team S19-G3, Livingston Winter 2018 Member of Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 943
