Shark Rocket Powerhead AH401 Filter Grille Replacement
  1. Shark Rocket Powerhead AH401 Filter Grille Replacement, Dust Cup: step 1, image 1 of 3 Shark Rocket Powerhead AH401 Filter Grille Replacement, Dust Cup: step 1, image 2 of 3 Shark Rocket Powerhead AH401 Filter Grille Replacement, Dust Cup: step 1, image 3 of 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  2. Shark Rocket Powerhead AH401 Filter Grille Replacement: step 2, image 1 of 2 Shark Rocket Powerhead AH401 Filter Grille Replacement: step 2, image 2 of 2
    • Remove the dust cup by lifting it off the dock.
  3. Shark Rocket Powerhead AH401 Filter Grille Replacement, Filter Grille: step 3, image 1 of 2 Shark Rocket Powerhead AH401 Filter Grille Replacement, Filter Grille: step 3, image 2 of 2
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  4. Shark Rocket Powerhead AH401 Filter Grille Replacement: step 4, image 1 of 2 Shark Rocket Powerhead AH401 Filter Grille Replacement: step 4, image 2 of 2
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
Shobhit Dabral
913 Reputation
6 Guides authored
Cal Poly, Team S19-G3, Livingston Winter 2018 Member of Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 304
