Shark Rocket Powerhead AH401 Brushroll Cap Replacement
  1. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: step 1, image 1 of 3 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: step 1, image 2 of 3 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: step 1, image 3 of 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Brushroll Cap Replacement: step 2, image 1 of 2 Shark Rocket Powerhead AH401 Brushroll Cap Replacement: step 2, image 2 of 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: step 3, image 1 of 3 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: step 3, image 2 of 3 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: step 3, image 3 of 3
    • Remove the cap by pushing the "pull" tab.
Shobhit Dabral
913 Reputation
6 Guides authored
Cal Poly, Team S19-G3, Livingston Winter 2018 Member of Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 17
All Time: 969
