Shark ION Robot 750 Charging Dock Motherboard Replacement
  1. Shark ION Robot 750 Charging Dock Motherboard Replacement, Charging Dock: step 1, image 1 of 1
    • Remove the three Torx T6 screws on the underside of the charging dock.
    • Lift off the lower case.
  2. Shark ION Robot 750 Charging Dock Motherboard Replacement: step 2, image 1 of 1
    • Using a Phillips #0 screwdriver, unscrew the four screws inside.
  3. Shark ION Robot 750 Charging Dock Motherboard Replacement: step 3, image 1 of 2 Shark ION Robot 750 Charging Dock Motherboard Replacement: step 3, image 2 of 2
    • Gently push in the tabs to remove the sensor housing.
  4. Shark ION Robot 750 Charging Dock Motherboard Replacement: step 4, image 1 of 1
    • Unplug the two wires going into the motherboard, then gently lift the motherboard up and out of its slot.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 67
