Shark Cordless Pet Perfect Front Motor Replacement
  1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: step 1, image 1 of 2 Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: step 1, image 2 of 2
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Motor  Replacement: step 2, image 1 of 3 Shark Cordless Pet Perfect Front Motor  Replacement: step 2, image 2 of 3 Shark Cordless Pet Perfect Front Motor  Replacement: step 2, image 3 of 3
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Motor  Replacement: step 3, image 1 of 3 Shark Cordless Pet Perfect Front Motor  Replacement: step 3, image 2 of 3 Shark Cordless Pet Perfect Front Motor  Replacement: step 3, image 3 of 3
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Motor  Replacement: step 4, image 1 of 2 Shark Cordless Pet Perfect Front Motor  Replacement: step 4, image 2 of 2
    • Remove the belt from the motor mount, and then replace with a new belt.
  5. Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: step 5, image 1 of 2 Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: step 5, image 2 of 2
    • Remove the solder from both motor terminals.
3 other people completed this guide.
Ashley Calkins
560 Reputation
3 Guides authored
USF Tampa, Team 16-2, Blackwell Spring 2017 Member of USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Members
11 Guides authored
2 Comments
Well done, Ashley! You might want to note that using a solder remover is helpful.
Jimbo - Reply
Where can I obtain the new motor with the plastic gear?
F V - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 2,646
