Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement
  1. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement, Earmuff: step 1, image 1 of 1
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: step 2, image 1 of 1
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement, Motherboard: step 3, image 1 of 1
    • Remove the 4 8mm screws with a #000 Philips screw driver.
  4. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: step 4, image 1 of 1
    • Remove the 2 2mm screws using a #000 phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: step 5, image 1 of 1
    • Using a soldering iron, remove all the wires attached to the motherboard and other components.
  6. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Finally, remove the blue ribbon plugged into the motherboard.
    • Make sure to do this using tweezers, so as to avoid any damage to the fragile ribbon.
nasaintj
159 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 48
All Time: 233
