Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement
  1. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Earmuff: step 1, image 1 of 1
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: step 2, image 1 of 1
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Charging Port/Volume Control: step 3, image 1 of 2 Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement, Charging Port/Volume Control: step 3, image 2 of 2
    • After removing the muffs, the speaker cover must be removed by unscrewing 4 3mm Phillips screws using a #000 Phillips screwdriver.
  4. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: step 4, image 1 of 1
    • After locating the circuit board that contains the charging port as well as the volume control dial, two 3 mm screws must be removed using a #000 phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Charging Port/Volume Control Replacement: step 5, image 1 of 1
    • Unplug the blue ribbon attaching the circuit board to the motherboard.
welsayed
319 Reputation
3 Guides authored
2 Comments
where do I get the replacement module?
Jan G - Reply
Have you found one yet? I've needed to do this repair for a while.
Paul B -
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 76
All Time: 322
