Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement
  1. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement, Earmuff: step 1, image 1 of 1
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 2, image 1 of 1
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement, Adjustable Sliding Hinges: step 3, image 1 of 1
    • Remove the four 8mm screws on the ear cup using a #000 Phillips screwdriver to reveal the motherboard.
  4. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 4, image 1 of 3 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 4, image 2 of 3 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 4, image 3 of 3
    • On one half of the ear cup that was previously removed, there will be located a motherboard. On the other half there will be a coupler holding the cup to the hinge and allowing it to move in a 360 degree manner. Remove this coupler by unscrewing the 10mm screw with the same #000 Phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 5, image 1 of 2 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 5, image 2 of 2
    • On the leather part of the headset, four 6mm Torx screws need to be removed using a T6H Torx screwdriver.
  6. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 6, image 1 of 2 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 6, image 2 of 2
    • On the other side of the 6mm torx screws, there is a nameplate that needs to be pried off using a pry tool.
  7. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 7, image 1 of 3 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 7, image 2 of 3 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: step 7, image 3 of 3
    • Steps 1-4 need to be repeated for the other ear cup.
The hinges must be removed from BOTH sides of the headphones for even one side to come out. They are attached together.
welsayed
319 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 171
