Sennheiser HD 4.50 Motherboard Replacement
  1. Sennheiser HD 4.50 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Sennheiser HD 4.50 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Locate the side designation on the headband-earpiece junction.
    • The motherboard is located on the right side.
    • Remove the right side ear pad.
    • Refer to the Ear Pad Removal guide for more guidance.
  2. Sennheiser HD 4.50 Motherboard Replacement: step 2, image 1 of 3 Sennheiser HD 4.50 Motherboard Replacement: step 2, image 2 of 3 Sennheiser HD 4.50 Motherboard Replacement: step 2, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry off the cover.
  3. Sennheiser HD 4.50 Motherboard Replacement: step 3, image 1 of 3 Sennheiser HD 4.50 Motherboard Replacement: step 3, image 2 of 3 Sennheiser HD 4.50 Motherboard Replacement: step 3, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the four 6 mm screws holding the motherboard in place.
  4. Sennheiser HD 4.50 Motherboard Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove the hot glue that covers the wires
    • Using the tweezers, grasp and slowly pull away the wires from the motherboard until they disconnect.
  5. Sennheiser HD 4.50 Motherboard Replacement: step 5, image 1 of 1
    • Use the iFixit opening tools to lift up on the motherboard.
    • While lifting up with the tool, grab and pull the motherboard with your free hand away from the button functions until it disconnects.
    • There may be some resistance in this step.
  6. Sennheiser HD 4.50 Motherboard Replacement: step 6, image 1 of 1
    • Desolder the three wires that are on the underside of the motherboard now that it is free.
    • Remove the motherboard.
2 other people completed this guide.
0 Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 107
All Time: 2,481
