Sennheiser HD 4.50 Headband Pad Replacement
  1. Sennheiser HD 4.50 Headband Pad Replacement, Headband Pad: step 1, image 1 of 2 Sennheiser HD 4.50 Headband Pad Replacement, Headband Pad: step 1, image 2 of 2
    • Extend the headphones by pulling the headband away from the base of the headphones.
    • Do this to both the right and left sides of the headphones.
  2. Sennheiser HD 4.50 Headband Pad Replacement: step 2, image 1 of 3 Sennheiser HD 4.50 Headband Pad Replacement: step 2, image 2 of 3 Sennheiser HD 4.50 Headband Pad Replacement: step 2, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the two screws on the silver piece on either edge of the headband.
    • Make sure to do this to both the right and left sides of the headphones.
    • After removing the screws, slide both silver pieces down.
  3. Sennheiser HD 4.50 Headband Pad Replacement: step 3, image 1 of 2 Sennheiser HD 4.50 Headband Pad Replacement: step 3, image 2 of 2
    • Grasp the headband pad firmly with your pointer finger and thumb and gently pull the pad away from the headband until the pad is fully removed.
    • You may need to apply adhesive when sticking the replacement headband pad back to the headband.
One Comment
Is there any guide on replacing the hinge that the ear cups are connected to?
Keoabetswe Morake - Reply
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 86
All Time: 2,566
