Sennheiser HD 4.50 Battery Replacement
  1. Sennheiser HD 4.50 Battery Replacement, Battery: step 1, image 1 of 1
    • Locate the side designation on the headband-earpiece junction.
    • The battery is on the left side.
    • The motherboard is on the right side.
  2. Sennheiser HD 4.50 Battery Replacement: step 2, image 1 of 3 Sennheiser HD 4.50 Battery Replacement: step 2, image 2 of 3 Sennheiser HD 4.50 Battery Replacement: step 2, image 3 of 3
  3. Sennheiser HD 4.50 Battery Replacement: step 3, image 1 of 3 Sennheiser HD 4.50 Battery Replacement: step 3, image 2 of 3 Sennheiser HD 4.50 Battery Replacement: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry open the cover.
    • Remove the cover.
  4. Sennheiser HD 4.50 Battery Replacement: step 4, image 1 of 1
    • Use a spudger to pry the battery from the plastic case.
    • The battery is held down by a strong adhesive, so it will give resistance.
  5. Sennheiser HD 4.50 Battery Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, pull the white battery connector upwards out of its socket.
    • Remove the battery.
7 other people completed this guide.
6 Comments
Hello ! Thanks for the tuto. Do you know where to buy the battery ?
Fren6 - Reply
You can search with the part number(Shown in the photo) : AHB622540N1/AHB622540N01.
Santanu Ghosal - Reply
Where i can find it
Erik Ridwan -
Does anyone know if I can use the he 450 bt replacement battery in a 350 bt headphone? The difference in the spec is that the 450’s battery has a longer battery life (2.2 wh vs. 1.3 wh)
M Lawson - Reply
This was pretty straightforward, but in opening the cap one of the tiny soldered wires pulled off the pad. It's so tiny that I don't have much hope of soldering it back. Any other way to reattach it? I put it back together anyways and now the right cup works fine, but the left is dead. I recommend a warning here about the little wires, if nothing else.
David Hook - Reply
Past 24 Hours: 17
Past 7 Days: 107
Past 30 Days: 536
All Time: 13,223
