Sega Genesis Motherboard Replacement
  1. Sega Genesis Motherboard Replacement, Outer Case: step 1, image 1 of 1
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Sega Genesis Motherboard Replacement: step 2, image 1 of 1
    • Flip the Sega Genesis upright.
  3. Sega Genesis Motherboard Replacement: step 3, image 1 of 1
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Sega Genesis Motherboard Replacement: step 4, image 1 of 1
    • Bend out the LED leads into vertical positions.
  5. Sega Genesis Motherboard Replacement: step 5, image 1 of 1
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  6. Sega Genesis Motherboard Replacement: step 6, image 1 of 1
    • Separate the main board from the outer case.
  7. Sega Genesis Motherboard Replacement, Motherboard: step 7, image 1 of 1
    • Remove single black screw from the outside of the bottom cover, using a Philips screwdriver.
  8. Sega Genesis Motherboard Replacement: step 8, image 1 of 1
    • Using a Philips screwdriver, remove 11 screws securing silver casing.
  9. Sega Genesis Motherboard Replacement: step 9, image 1 of 1
    • Remove silver case.
  10. Sega Genesis Motherboard Replacement: step 10, image 1 of 1
    • Remove single golden screw on motherboard using Philips screwdriver.
    • Note: Push headphone jack to the side.
  11. Sega Genesis Motherboard Replacement: step 11, image 1 of 1
    • Remove two black screws on the left and right sides of the cartridge slot.
  12. Sega Genesis Motherboard Replacement: step 12, image 1 of 1
    • Remove motherboard.
  13. Sega Genesis Motherboard Replacement: step 13, image 1 of 1
    • Re-install new motherboard.
13 other people completed this guide.
Erik Bjornstrom
829 Reputation
3 Guides authored
Cal Poly, Team 3-29, Regan Fall 2010 Member of Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 40
Past 30 Days: 209
All Time: 32,978
