Screen Disconnection
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Screen Disconnection, Unfasten the display cable bracket: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the five screws securing the display cable bracket:
    • Four 1.1 mm-long screws
    • One 2.0 mm-long screw
  2. Screen Disconnection, Remove the display cable bracket: step 2, image 1 of 2 Screen Disconnection, Remove the display cable bracket: step 2, image 2 of 2
    • Use tweezers, or your fingers, to remove the display cable bracket.
  3. Screen Disconnection, Disconnect the top display cables: step 3, image 1 of 3 Screen Disconnection, Disconnect the top display cables: step 3, image 2 of 3 Screen Disconnection, Disconnect the top display cables: step 3, image 3 of 3
    • Use a spudger to pry up and disconnect the two top display cable press connectors.
  4. Screen Disconnection, Disconnect the bottom display cables: step 4, image 1 of 3 Screen Disconnection, Disconnect the bottom display cables: step 4, image 2 of 3 Screen Disconnection, Disconnect the bottom display cables: step 4, image 3 of 3
    • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
  5. Screen Disconnection, Remove the screen: step 5, image 1 of 3 Screen Disconnection, Remove the screen: step 5, image 2 of 3 Screen Disconnection, Remove the screen: step 5, image 3 of 3
    • Remove the screen.
Alex Diaz-Kokaisl
124,319 Reputation
581 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,218 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1
