Satechi Aluminum Keyboard Disassembly
    • The power switch is located above the numpad on the vertical side of the keyboard
  1. Satechi Aluminum Keyboard Disassembly, Removing the bottom plate: step 2, image 1 of 3 Satechi Aluminum Keyboard Disassembly, Removing the bottom plate: step 2, image 2 of 3 Satechi Aluminum Keyboard Disassembly, Removing the bottom plate: step 2, image 3 of 3
    • Remove the rubber feet (they are simply glued in place)
    • Use a heat source to soften the adhesive that holds down the bottom plate
    • Check the pictures to see where the adhesive is applied inside the device
    • Use a plastic pick or some other tool to cut through the adhesive
    • Remove the bottom plate
  2. Satechi Aluminum Keyboard Disassembly, Removing the top cover: step 3, image 1 of 3 Satechi Aluminum Keyboard Disassembly, Removing the top cover: step 3, image 2 of 3 Satechi Aluminum Keyboard Disassembly, Removing the top cover: step 3, image 3 of 3
    • In order to get to the electronics inside we have to first remove the aluminium top cover
    • This is necessary because the plastic with the electronics underneath is clued to the top cover and is not removable without removing the clue
    • To remove the top cover first check out the images to see where to adhesive is applied on the cover
    • Use some heat source to soften the adhesive
    • Use a plastic pick or some other tool to cut through the adhesive (if the adhesive is really soft then simply applying pressure to the keycaps can help remove the cover)
    • Remove the cover
  3. Satechi Aluminum Keyboard Disassembly, Remove plastic cover: step 4, image 1 of 3 Satechi Aluminum Keyboard Disassembly, Remove plastic cover: step 4, image 2 of 3 Satechi Aluminum Keyboard Disassembly, Remove plastic cover: step 4, image 3 of 3
    • Start by removing the twelve Phillips #00 screws marked in the picture
    • Now you should be able to lift the plastic cover
  4. Satechi Aluminum Keyboard Disassembly, Battery close up: step 5, image 1 of 1
    • Insert wisdom here.
Freeness2359
129 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 41
All Time: 240
