Sanyo VPC-T850 Battery Replacement
  1. Sanyo VPC-T850 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Battery Replacement: step 2, image 1 of 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Battery Replacement: step 3, image 1 of 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Battery Replacement: step 4, image 1 of 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
James Robinson
459 Reputation
4 Guides authored
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 897
