Samsung WB350F Rear Case Replacement
  1. Samsung WB350F Rear Case Replacement, Rear Case: step 1, image 1 of 3 Samsung WB350F Rear Case Replacement, Rear Case: step 1, image 2 of 3 Samsung WB350F Rear Case Replacement, Rear Case: step 1, image 3 of 3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Rear Case Replacement: step 2, image 1 of 3 Samsung WB350F Rear Case Replacement: step 2, image 2 of 3 Samsung WB350F Rear Case Replacement: step 2, image 3 of 3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Rear Case Replacement: step 3, image 1 of 3 Samsung WB350F Rear Case Replacement: step 3, image 2 of 3 Samsung WB350F Rear Case Replacement: step 3, image 3 of 3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Rear Case Replacement: step 4, image 1 of 1
    • Remove the plastic casing, exposing the inner workings of the camera.
Zachary Bourgault
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 705
