Samsung Series 9 NP900X4D-A03US Battery Replacement
  1. Samsung Series 9 NP900X4D-A03US Battery Replacement, Battery: step 1, image 1 of 2 Samsung Series 9 NP900X4D-A03US Battery Replacement, Battery: step 1, image 2 of 2
    • Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
    • Use an iFixit opening tool to carefully remove the back panel from the laptop.
  2. Samsung Series 9 NP900X4D-A03US Battery Replacement: step 2, image 1 of 1
    • Remove the seven 0.5 mm Phillips #00 screws.
  3. Samsung Series 9 NP900X4D-A03US Battery Replacement: step 3, image 1 of 3 Samsung Series 9 NP900X4D-A03US Battery Replacement: step 3, image 2 of 3 Samsung Series 9 NP900X4D-A03US Battery Replacement: step 3, image 3 of 3
    • Lightly place some pressure into the highlighted cavity on the battery's outlet plug with a spudger.
    • Carefully remove the wires from the outlet plug.
    • Now you will be able to remove the battery from its place.
April Vo
124 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 1,235
