Samsung Series 9 NP900X4B-A02 Speaker Replacement
  1. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: step 1, image 1 of 2 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: step 1, image 2 of 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 Speaker Replacement: step 2, image 1 of 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 Speaker Replacement: step 3, image 1 of 2 Samsung Series 9 NP900X4B-A02 Speaker Replacement: step 3, image 2 of 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 Speaker Replacement: step 4, image 1 of 1
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: step 5, image 1 of 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: step 5, image 2 of 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: step 5, image 3 of 3
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 Speaker Replacement: step 6, image 1 of 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement: step 6, image 2 of 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement: step 6, image 3 of 3
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
Brady Hildreth
361 Reputation
3 Guides authored
IUPUI, Team S1-G4, Henning Fall 2019 Member of IUPUI, Team S1-G4, Henning Fall 2019
IUPUI-HENNING-F19S1G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 646
