Samsung Series 9 NP900X4B-A02 I/O PCB Replacement
  1. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: step 1, image 1 of 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: step 1, image 2 of 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 2, image 1 of 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 3, image 1 of 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 3, image 2 of 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 4, image 1 of 1
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: step 5, image 1 of 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: step 5, image 2 of 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: step 5, image 3 of 3
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 6, image 1 of 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 6, image 2 of 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 6, image 3 of 3
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
  7. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: step 7, image 1 of 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: step 7, image 2 of 2
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  8. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 8, image 1 of 1
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  9. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 9, image 1 of 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  10. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 10, image 1 of 1
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
  11. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, I/O PCB: step 11, image 1 of 1
    • Remove the five 2.5 mm Phillips #00 screws securing the I/O PCB.
  12. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 12, image 1 of 1
    • Lift and pull the SSD from the board.
  13. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 13, image 1 of 1
    • Disconnect the black press fit connector by gently lifting up.
  14. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 14, image 1 of 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: step 14, image 2 of 2
    • Lift the right side of the I/O PCB and pull to the right to remove it from the laptop casing.
Brady Hildreth
361 Reputation
3 Guides authored
IUPUI, Team S1-G4, Henning Fall 2019 Member of IUPUI, Team S1-G4, Henning Fall 2019
IUPUI-HENNING-F19S1G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 273
