Samsung SPH-M360 Keyboard Replacement
  1. Samsung SPH-M360 Keyboard Replacement, Battery: step 1, image 1 of 3 Samsung SPH-M360 Keyboard Replacement, Battery: step 1, image 2 of 3 Samsung SPH-M360 Keyboard Replacement, Battery: step 1, image 3 of 3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Keyboard Replacement: step 2, image 1 of 3 Samsung SPH-M360 Keyboard Replacement: step 2, image 2 of 3 Samsung SPH-M360 Keyboard Replacement: step 2, image 3 of 3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Samsung SPH-M360 Keyboard Replacement, Casing: step 3, image 1 of 1
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Samsung SPH-M360 Keyboard Replacement: step 4, image 1 of 2 Samsung SPH-M360 Keyboard Replacement: step 4, image 2 of 2
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Samsung SPH-M360 Keyboard Replacement: step 5, image 1 of 2 Samsung SPH-M360 Keyboard Replacement: step 5, image 2 of 2
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
  6. Samsung SPH-M360 Keyboard Replacement, Keyboard: step 6, image 1 of 1
    • Flip open the phone so that the text on the keyboard is visible.
    • Push from the text side until the keyboard comes completely out of the phone casing.
Hunter Parker
475 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 86
