Samsung SPH-A500 Keypad Replacement
  1. Samsung SPH-A500 Keypad Replacement, Keypad: step 1, image 1 of 1
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Samsung SPH-A500 Keypad Replacement: step 2, image 1 of 1
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Samsung SPH-A500 Keypad Replacement: step 3, image 1 of 1
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Samsung SPH-A500 Keypad Replacement: step 4, image 1 of 1
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  5. Samsung SPH-A500 Keypad Replacement: step 5, image 1 of 1
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
  6. Samsung SPH-A500 Keypad Replacement: step 6, image 1 of 1
    • Lift circuit board from the bottom of the phone.
    • WARNING: DO NOT completely remove circuit board from the phone, since it is still attached at the top of the phone.
  7. Samsung SPH-A500 Keypad Replacement: step 7, image 1 of 1
    • Flip the circuit board around the top of the phone.
    • Lift the rubber keypad off.
  8. Samsung SPH-A500 Keypad Replacement: step 8, image 1 of 1
    • Replace the keypad.
Nick Dominikovic
139 Reputation
4 Guides authored
Cal Poly, Team 18-100, Johann Spring 2010 Member of Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,811
