Samsung SGH-E317 Camera Replacement
  1. Samsung SGH-E317 Camera Replacement, Camera: step 1, image 1 of 2 Samsung SGH-E317 Camera Replacement, Camera: step 1, image 2 of 2
    • Remove the plastic coverings at the base of the LCD screen using your fingers.
  2. Samsung SGH-E317 Camera Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Use the screwdriver to remove the two 4.5mm screws located underneath the plastic coverings.
    • You may want to use tweezers to remove the loosened screws.
  3. Samsung SGH-E317 Camera Replacement: step 3, image 1 of 1
    • Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
    • Gently pry the top panel off around the entire frame.
  4. Samsung SGH-E317 Camera Replacement: step 4, image 1 of 2 Samsung SGH-E317 Camera Replacement: step 4, image 2 of 2
    • Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
  5. Samsung SGH-E317 Camera Replacement: step 5, image 1 of 1
    • Take the top panel off of the phone.
  6. Samsung SGH-E317 Camera Replacement: step 6, image 1 of 2 Samsung SGH-E317 Camera Replacement: step 6, image 2 of 2
    • Use the wedge to detach the connecting wire panel from the LCD display system.
    • Be gentle when dethatching this wire to prevent damaging surrounding components.
  7. Samsung SGH-E317 Camera Replacement: step 7, image 1 of 2 Samsung SGH-E317 Camera Replacement: step 7, image 2 of 2
    • Use the tweezers to remove the camera from the cellphone casing.
Michael Strange
101 Reputation
1 Guide authored
Cal Poly, Team 11-23, Maness Winter 2011 Member of Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,521
