Samsung SGH-A237 Logic Board Replacement
  1. Samsung SGH-A237 Logic Board Replacement, Logic Board: step 1, image 1 of 2 Samsung SGH-A237 Logic Board Replacement, Logic Board: step 1, image 2 of 2
    • Put the phone face down so that the battery cover is showing.
  2. Samsung SGH-A237 Logic Board Replacement: step 2, image 1 of 2 Samsung SGH-A237 Logic Board Replacement: step 2, image 2 of 2
    • Use your thumb to push the cover down and off.
    • Lift the battery off the device.
  3. Samsung SGH-A237 Logic Board Replacement: step 3, image 1 of 2 Samsung SGH-A237 Logic Board Replacement: step 3, image 2 of 2
    • Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Logic Board Replacement: step 4, image 1 of 3 Samsung SGH-A237 Logic Board Replacement: step 4, image 2 of 3 Samsung SGH-A237 Logic Board Replacement: step 4, image 3 of 3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Note: some force must be applied when removing back cover.
  5. Samsung SGH-A237 Logic Board Replacement: step 5, image 1 of 1
    • Detach the tab from the logic board by using iPod Opening Tool (as shown).
  6. Samsung SGH-A237 Logic Board Replacement: step 6, image 1 of 2 Samsung SGH-A237 Logic Board Replacement: step 6, image 2 of 2
    • Use iPod Opening Tool to lift the green logic board carefully.
    • Remove logic board from the device and replace with new one.
Theodore Johansen
1 Reputation
2 Guides authored
Cal Poly, Team 29-81, Johann Spring 2010 Member of Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,806
