Samsung Rogue Motherboard Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Samsung Rogue Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  2. Samsung Rogue Motherboard Replacement: step 2, image 1 of 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  3. Samsung Rogue Motherboard Replacement: step 3, image 1 of 3 Samsung Rogue Motherboard Replacement: step 3, image 2 of 3 Samsung Rogue Motherboard Replacement: step 3, image 3 of 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  4. Samsung Rogue Motherboard Replacement: step 4, image 1 of 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  5. Samsung Rogue Motherboard Replacement: step 5, image 1 of 2 Samsung Rogue Motherboard Replacement: step 5, image 2 of 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  6. Samsung Rogue Motherboard Replacement: step 6, image 1 of 2 Samsung Rogue Motherboard Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
Viktoria Mikoultchik
25 Reputation
7 Guides authored
Cal Poly, Team 7-32, Maness Spring 2012 Member of Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 229
