Samsung Rogue Keyboard Replacement
  1. Samsung Rogue Keyboard Replacement, Battery: step 1, image 1 of 2 Samsung Rogue Keyboard Replacement, Battery: step 1, image 2 of 2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Keyboard Replacement: step 2, image 1 of 2 Samsung Rogue Keyboard Replacement: step 2, image 2 of 2
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Keyboard Replacement, Motherboard: step 3, image 1 of 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Keyboard Replacement: step 4, image 1 of 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Keyboard Replacement: step 5, image 1 of 3 Samsung Rogue Keyboard Replacement: step 5, image 2 of 3 Samsung Rogue Keyboard Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Keyboard Replacement: step 6, image 1 of 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Keyboard Replacement: step 7, image 1 of 2 Samsung Rogue Keyboard Replacement: step 7, image 2 of 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Keyboard Replacement: step 8, image 1 of 2 Samsung Rogue Keyboard Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Keyboard Replacement, Keyboard: step 9, image 1 of 1
    • Remove the eight 1.7mm Philips screws above the keyboard.
  10. Samsung Rogue Keyboard Replacement: step 10, image 1 of 1
    • Carefully remove keyboard holder from the slider mechanisms underneath.
  11. Samsung Rogue Keyboard Replacement: step 11, image 1 of 2 Samsung Rogue Keyboard Replacement: step 11, image 2 of 2
    • Turn keyboard holder over and allow the keyboard to simply fall out into your hand.
Viktoria Mikoultchik
25 Reputation
7 Guides authored
Cal Poly, Team 7-32, Maness Spring 2012 Member of Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 11
All Time: 309
