Samsung Portable Dualband Tri-Mode Keypad Replacement
  1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Battery: step 1, image 1 of 2 Samsung Portable Dualband Tri-Mode Keypad Replacement, Battery: step 1, image 2 of 2
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Samsung Portable Dualband Tri-Mode Keypad Replacement, Antenna: step 2, image 1 of 2 Samsung Portable Dualband Tri-Mode Keypad Replacement, Antenna: step 2, image 2 of 2
    • Unscrew the antenna top.
  3. Samsung Portable Dualband Tri-Mode Keypad Replacement: step 3, image 1 of 3 Samsung Portable Dualband Tri-Mode Keypad Replacement: step 3, image 2 of 3 Samsung Portable Dualband Tri-Mode Keypad Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  4. Samsung Portable Dualband Tri-Mode Keypad Replacement, Backplate: step 4, image 1 of 3 Samsung Portable Dualband Tri-Mode Keypad Replacement, Backplate: step 4, image 2 of 3 Samsung Portable Dualband Tri-Mode Keypad Replacement, Backplate: step 4, image 3 of 3
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  5. Samsung Portable Dualband Tri-Mode Keypad Replacement, Motherboard: step 5, image 1 of 3 Samsung Portable Dualband Tri-Mode Keypad Replacement, Motherboard: step 5, image 2 of 3 Samsung Portable Dualband Tri-Mode Keypad Replacement, Motherboard: step 5, image 3 of 3
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  6. Samsung Portable Dualband Tri-Mode Keypad Replacement, Keypad: step 6, image 1 of 3 Samsung Portable Dualband Tri-Mode Keypad Replacement, Keypad: step 6, image 2 of 3 Samsung Portable Dualband Tri-Mode Keypad Replacement, Keypad: step 6, image 3 of 3
    • Remove the gray keypad from the phone by peeling it back.
  7. Samsung Portable Dualband Tri-Mode Keypad Replacement: step 7, image 1 of 2 Samsung Portable Dualband Tri-Mode Keypad Replacement: step 7, image 2 of 2
    • Remove the black keypad from the phone casing.
    • Clean the keypad and check for any damage. If the keypad is damaged, then replace it with a new one.
Barbara
413 Reputation
4 Guides authored
Clemson, Team 6-2, Benson Spring 2014 Member of Clemson, Team 6-2, Benson Spring 2014
CLEM-BENSON-S14S6G2
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 192
