Samsung Odyssey NP800G5M Fan Replacement
  1. Samsung Odyssey NP800G5M Fan Replacement, Battery: step 1, image 1 of 1
    • Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
  2. Samsung Odyssey NP800G5M Fan Replacement: step 2, image 1 of 2 Samsung Odyssey NP800G5M Fan Replacement: step 2, image 2 of 2
    • Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
    • Work your way around the body of the laptop until the back cover is completely separated.
    • Remove the back casing.
  3. Samsung Odyssey NP800G5M Fan Replacement: step 3, image 1 of 2 Samsung Odyssey NP800G5M Fan Replacement: step 3, image 2 of 2
    • Disconnect the battery connector cable.
    • Working on the device without removing the battery connector cable can damage major components of the device.
  4. Samsung Odyssey NP800G5M Fan Replacement: step 4, image 1 of 3 Samsung Odyssey NP800G5M Fan Replacement: step 4, image 2 of 3 Samsung Odyssey NP800G5M Fan Replacement: step 4, image 3 of 3
    • Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  5. Samsung Odyssey NP800G5M Fan Replacement, Fan: step 5, image 1 of 3 Samsung Odyssey NP800G5M Fan Replacement, Fan: step 5, image 2 of 3 Samsung Odyssey NP800G5M Fan Replacement, Fan: step 5, image 3 of 3
    • Disconnect the fans from the motherboard by pulling the plugs away from their connectors.
    • Using the Phillips #0 screwdriver, remove the four 4.6mm screws.
    • Using the same screwdriver, unscrew the six screws surrounding the heat sink.
    • These screws cannot be removed from the device.
    • Remove the fan assembly from the device.
4 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 17
All Time: 1,226
