Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement
  1. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement, Battery: step 1, image 1 of 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 2, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 3, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 4, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 5, image 1 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 5, image 2 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 5, image 3 of 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement, Touch Screen: step 6, image 1 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement, Touch Screen: step 6, image 2 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement, Touch Screen: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the connections for the screen using a pair of tweezers or your fingers.
  7. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 7, image 1 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 7, image 2 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 7, image 3 of 3
    • Remove the four 4.5mm screws using a Phillips #00 screwdriver that connect the top and bottom of the computer through the hinge.
  8. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 8, image 1 of 1
    • Separate the top and bottom of the computer.
  9. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 9, image 1 of 1
    • Gently remove the screen guard on the front end using the plastic opening tool.
  10. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 10, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 10, image 2 of 2
    • Heat the iFixit iOpener in the microwave for 30-45 seconds and apply it to the edges of the screen to loosen the adhesive.
    • iOpener will be HOT. Exercise caution.
  11. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 11, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 11, image 2 of 2
    • Once enough heat has been applied, use the plastic opening tool and the metal spudger to separate the screen from the backing.
    • Using the metal spudger may severely damage the internal components of your device. Using the metal spudger to remove any glass component is especiallydangerous and may cause harm to the device and the user.
    • The adhesive is thickest in the corners.
  12. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 12, image 1 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 12, image 2 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 12, image 3 of 3
    • Use the suction cup to raise the screen backing with care. Do not remove the screen from the device yet as there are cables connected along the bottom.
  13. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 13, image 1 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 13, image 2 of 3 Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 13, image 3 of 3
    • Use tweezers to detach the cables connecting to the back of the screen.
  14. Samsung Notebook 7 Spin NP740U3MK01US Touch Screen Replacement: step 14, image 1 of 1
    • Remove the screen and use tweezers to remove any shards of glass.
2 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 24
All Time: 2,806
