Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement
  1. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement, Battery: step 1, image 1 of 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 2, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 3, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 4, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 5, image 1 of 3 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 5, image 2 of 3 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 5, image 3 of 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement, RAM: step 6, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement, RAM: step 6, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the five 4.5 mm screws.
  7. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 7, image 1 of 2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: step 7, image 2 of 2
    • Push these clamps outwards away from the RAM. The RAM should pop out.
    • Remove the RAM from the device. Repeat the same step for any additional RAM.
One Comment
If my laptop already has 12 GB of RAM, is it possible to increase it to 24 GB? what would the limit be? I have read somewhere else it is 12 GB.
In that case, would the remaining slot be useless, or does my laptop come with two 6 GB RAM boards, one for each slot
David Hijar - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,076
