Samsung NP900X4B Fan Replacement
  1. Samsung NP900X4B Fan Replacement, Back Panel: step 1, image 1 of 2 Samsung NP900X4B Fan Replacement, Back Panel: step 1, image 2 of 2
    • First turn the computer over so you are looking at the back panel.
    • Next locate all ten Phillips #0 3.5mm screws on the back panel that are securing it down.
  2. Samsung NP900X4B Fan Replacement: step 2, image 1 of 1
    • Next remove all 3.5mm Phillips #0 screws shown in the previous step.
  3. Samsung NP900X4B Fan Replacement: step 3, image 1 of 2 Samsung NP900X4B Fan Replacement: step 3, image 2 of 2
    • After all screws are removed, lift up the back panel as shown.
  4. Samsung NP900X4B Fan Replacement, Fan: step 4, image 1 of 2 Samsung NP900X4B Fan Replacement, Fan: step 4, image 2 of 2
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  5. Samsung NP900X4B Fan Replacement: step 5, image 1 of 1
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  6. Samsung NP900X4B Fan Replacement: step 6, image 1 of 2 Samsung NP900X4B Fan Replacement: step 6, image 2 of 2
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  7. Samsung NP900X4B Fan Replacement: step 7, image 1 of 1
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
Brian Miller
333 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 174
