Samsung NP540U3C-A02UB Fan Replacement
  1. Samsung NP540U3C-A02UB Fan Replacement, Fan: step 1, image 1 of 1
    • Turn off the laptop and disconnect from the charging cable before beginning disassembly.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Fan Replacement: step 2, image 1 of 2 Samsung NP540U3C-A02UB Fan Replacement: step 2, image 2 of 2
    • Remove the 1x 4mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Fan Replacement: step 3, image 1 of 3 Samsung NP540U3C-A02UB Fan Replacement: step 3, image 2 of 3 Samsung NP540U3C-A02UB Fan Replacement: step 3, image 3 of 3
    • Gently release the three clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Fan Replacement: step 4, image 1 of 1
    • Peel the yellow tape up so it no longer blocks the fan's wires and screw.
  5. Samsung NP540U3C-A02UB Fan Replacement: step 5, image 1 of 1
    • Remove the two 2.4mm Phillips #00 screws attaching the fan to the case.
    • Remove the two 6mm Phillips #00 screws attaching the fan to the case.
  6. Samsung NP540U3C-A02UB Fan Replacement: step 6, image 1 of 2 Samsung NP540U3C-A02UB Fan Replacement: step 6, image 2 of 2
    • Using the plastic opening tool, gently disconnect the fan from the motherboard by unplugging the wire.
  7. Samsung NP540U3C-A02UB Fan Replacement: step 7, image 1 of 1
    • Remove the fan from the case.
Colby Bolger
277 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 262
