Samsung NP350E5C-A02US Wifi card Replacement
  1. Samsung NP350E5C-A02US Wifi card Replacement, Battery: step 1, image 1 of 1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US Wifi card Replacement: step 2, image 1 of 1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US Wifi card Replacement: step 3, image 1 of 1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US Wifi card Replacement, Wifi card: step 4, image 1 of 1
    • Look for the compartment with the Wifi symbol on it.
  5. Samsung NP350E5C-A02US Wifi card Replacement: step 5, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the 5 mm screw located beside the Wifi symbol.
  6. Samsung NP350E5C-A02US Wifi card Replacement: step 6, image 1 of 1
    • Gently pry up cover using a plastic spudger or opening tool.
  7. Samsung NP350E5C-A02US Wifi card Replacement: step 7, image 1 of 1
    • Gently remove the two wires attached to the Wifi card by using a plastic opening tool or plastic spudger to pry up from under where the wire is attached.
  8. Samsung NP350E5C-A02US Wifi card Replacement: step 8, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the M2.5x3 mm screw holding in the Wifi card.
  9. Samsung NP350E5C-A02US Wifi card Replacement: step 9, image 1 of 1
    • Gently pull out the Wifi card.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 259
