Samsung NP350E5C-A02US RAM Replacement
  1. Samsung NP350E5C-A02US RAM Replacement, Battery: step 1, image 1 of 1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US RAM Replacement: step 2, image 1 of 1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US RAM Replacement: step 3, image 1 of 1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US RAM Replacement, Hard drive and memory stick cover: step 4, image 1 of 1
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  5. Samsung NP350E5C-A02US RAM Replacement: step 5, image 1 of 1
    • Slide the cover 1/4" towards the front of the laptop.
  6. Samsung NP350E5C-A02US RAM Replacement: step 6, image 1 of 1
    • Then, lift the cover off.
  7. Samsung NP350E5C-A02US RAM Replacement, RAM: step 7, image 1 of 1
    • Gently push the lock springs outwards and the RAM stick will rise when it's free.
  8. Samsung NP350E5C-A02US RAM Replacement: step 8, image 1 of 1
    • Then, gently pull the RAM stick towards the front of the laptop.
  9. Samsung NP350E5C-A02US RAM Replacement: step 9, image 1 of 1
    • Repeat the last two steps for the second RAM stick if needed.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 264
