Samsung NP-NC10-KA02US Fan Replacement
  1. Samsung NP-NC10-KA02US Fan Replacement, Battery: step 1, image 1 of 2 Samsung NP-NC10-KA02US Fan Replacement, Battery: step 1, image 2 of 2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US Fan Replacement: step 2, image 1 of 1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US Fan Replacement: step 3, image 1 of 1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US Fan Replacement, Back Plate: step 4, image 1 of 1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US Fan Replacement: step 5, image 1 of 1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US Fan Replacement: step 6, image 1 of 2 Samsung NP-NC10-KA02US Fan Replacement: step 6, image 2 of 2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US Fan Replacement, Fan: step 7, image 1 of 2 Samsung NP-NC10-KA02US Fan Replacement, Fan: step 7, image 2 of 2
    • Remove the three screws holding the fan using a 3.9mm screwdriver.
    • All three screws need to be removed in order to continue on to next step.
  8. Samsung NP-NC10-KA02US Fan Replacement: step 8, image 1 of 1
    • Unplug the wires connected to the fan using a plastic opening tool.
  9. Samsung NP-NC10-KA02US Fan Replacement: step 9, image 1 of 1
    • You are now able to carefully detach the fan from the base.
2 other people completed this guide.
JHOAN USECHE
372 Reputation
2 Guides authored
USF Tampa, Team 1-1, Sullivan Fall 2016 Member of USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 12
All Time: 692
