Samsung NP-N145-JP02US Screen Replacement
  1. Samsung NP-N145-JP02US Screen Replacement, Screen: step 1, image 1 of 1
    • Before starting replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Screen Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
    • Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
  3. Samsung NP-N145-JP02US Screen Replacement: step 3, image 1 of 1
    • Use a blue prying tool to pry the screen frame off.
    • Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
  4. Samsung NP-N145-JP02US Screen Replacement: step 4, image 1 of 3 Samsung NP-N145-JP02US Screen Replacement: step 4, image 2 of 3 Samsung NP-N145-JP02US Screen Replacement: step 4, image 3 of 3
    • Using your fingertips, gently pull screen to pop it out of the frame.
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 16
All Time: 420
