Samsung NP N310 HAA2US Back Panel Replacement
  1. Samsung NP N310 HAA2US Back Panel Replacement, Battery: step 1, image 1 of 3 Samsung NP N310 HAA2US Back Panel Replacement, Battery: step 1, image 2 of 3 Samsung NP N310 HAA2US Back Panel Replacement, Battery: step 1, image 3 of 3
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US Back Panel Replacement, Back Panel: step 2, image 1 of 2 Samsung NP N310 HAA2US Back Panel Replacement, Back Panel: step 2, image 2 of 2
    • Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
    • If there are rubber pads covering the screws, use a spudger to remove the rubber pads.
  3. Samsung NP N310 HAA2US Back Panel Replacement: step 3, image 1 of 3 Samsung NP N310 HAA2US Back Panel Replacement: step 3, image 2 of 3 Samsung NP N310 HAA2US Back Panel Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool in the break between the back panel, and the keyboard.
    • Drag the opening tool around the edge to separate it.
    • Pull the back panel off of the laptop.
Amir Afridi
626 Reputation
6 Guides authored
USF Tampa, Team 4-1, Passmore Fall 2016 Member of USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 307
