Samsung LN-T5265F T-Con Board Replacement
  1. Samsung LN-T5265F T-Con Board Replacement, Stand: step 1, image 1 of 1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F T-Con Board Replacement, Rear Case: step 3, image 1 of 2 Samsung LN-T5265F T-Con Board Replacement, Rear Case: step 3, image 2 of 2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
  3. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: step 4, image 1 of 2 Samsung LN-T5265F T-Con Board Replacement, T-Con Board: step 4, image 2 of 2
    • The Timing Controller (T-Con) board is located at the top center behind a metal shield.
    • Remove four Phillips screws.
    • Tilt the metal shield towards the top of the TV and lift away.
  4. Samsung LN-T5265F T-Con Board Replacement: step 5, image 1 of 1
    • Disconnect the two ribbon cables at the top by flipping up the retaining flaps and sliding the ribbons straight up towards the top of the TV.
  5. Samsung LN-T5265F T-Con Board Replacement: step 6, image 1 of 1
    • Disconnect the bottom ribbon cable by depressing the two buttons on either side of the connector and sliding down towards the bottom of the TV.
3 other people completed this guide.
Steven Carlton
606 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 10,095
