Samsung HMX-W300 USB Port Replacement
  1. Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: step 1, image 1 of 3 Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: step 1, image 2 of 3 Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: step 1, image 3 of 3
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 USB Port Replacement: step 2, image 1 of 2 Samsung HMX-W300 USB Port Replacement: step 2, image 2 of 2
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 USB Port Replacement: step 3, image 1 of 3 Samsung HMX-W300 USB Port Replacement: step 3, image 2 of 3 Samsung HMX-W300 USB Port Replacement: step 3, image 3 of 3
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 USB Port Replacement: step 4, image 1 of 3 Samsung HMX-W300 USB Port Replacement: step 4, image 2 of 3 Samsung HMX-W300 USB Port Replacement: step 4, image 3 of 3
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 USB Port Replacement: step 5, image 1 of 3 Samsung HMX-W300 USB Port Replacement: step 5, image 2 of 3 Samsung HMX-W300 USB Port Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 USB Port Replacement, Battery: step 6, image 1 of 2 Samsung HMX-W300 USB Port Replacement, Battery: step 6, image 2 of 2
    • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
  7. Samsung HMX-W300 USB Port Replacement: step 7, image 1 of 1
    • Use the iFixit opening tool to pry the battery housing open.
  8. Samsung HMX-W300 USB Port Replacement: step 8, image 1 of 3 Samsung HMX-W300 USB Port Replacement: step 8, image 2 of 3 Samsung HMX-W300 USB Port Replacement: step 8, image 3 of 3
    • After removing the battery housing, take the battery out.
  9. Samsung HMX-W300 USB Port Replacement, USB Port: step 9, image 1 of 3 Samsung HMX-W300 USB Port Replacement, USB Port: step 9, image 2 of 3 Samsung HMX-W300 USB Port Replacement, USB Port: step 9, image 3 of 3
    Buy
    • Use an iFixit opening tool to pry up the plastic cover.
    • Use tweezers to remove the wire from the slots.
  10. Samsung HMX-W300 USB Port Replacement: step 10, image 1 of 2 Samsung HMX-W300 USB Port Replacement: step 10, image 2 of 2
    • Remove both screws from the USB port using a Phillips #00 screwdriver.
  11. Samsung HMX-W300 USB Port Replacement: step 11, image 1 of 2 Samsung HMX-W300 USB Port Replacement: step 11, image 2 of 2
    • Push the USB port inside the case to remove it from the device.
Robert
966 Reputation
8 Guides authored
USF Tampa, Team 9-2, Blackwell Winter 2015 Member of USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 437
