Samsung HMX-W300 Rear Case Replacement
  1. Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: step 1, image 1 of 3 Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: step 1, image 2 of 3 Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: step 1, image 3 of 3
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 Rear Case Replacement: step 2, image 1 of 2 Samsung HMX-W300 Rear Case Replacement: step 2, image 2 of 2
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Rear Case Replacement: step 3, image 1 of 3 Samsung HMX-W300 Rear Case Replacement: step 3, image 2 of 3 Samsung HMX-W300 Rear Case Replacement: step 3, image 3 of 3
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 Rear Case Replacement: step 4, image 1 of 3 Samsung HMX-W300 Rear Case Replacement: step 4, image 2 of 3 Samsung HMX-W300 Rear Case Replacement: step 4, image 3 of 3
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Rear Case Replacement: step 5, image 1 of 3 Samsung HMX-W300 Rear Case Replacement: step 5, image 2 of 3 Samsung HMX-W300 Rear Case Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Rear Case Replacement, Remove tape.: step 6, image 1 of 3 Samsung HMX-W300 Rear Case Replacement, Remove tape.: step 6, image 2 of 3 Samsung HMX-W300 Rear Case Replacement, Remove tape.: step 6, image 3 of 3
    Buy
  7. Samsung HMX-W300 Rear Case Replacement, Unplug wire ribbon.: step 7, image 1 of 2 Samsung HMX-W300 Rear Case Replacement, Unplug wire ribbon.: step 7, image 2 of 2
    • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
  8. Samsung HMX-W300 Rear Case Replacement, Remove scerws.: step 8, image 1 of 2 Samsung HMX-W300 Rear Case Replacement, Remove scerws.: step 8, image 2 of 2
    • There are 5 Phillips size 00 screws. Remove all 5 screws.
    • Wire ribbon is attached to the motherboard.
  9. Samsung HMX-W300 Rear Case Replacement: step 9, image 1 of 1
    • Pry the motherboard up using the plastic opening tool.
    • Be careful there is a wire ribbon holding the motherboard.
  10. Samsung HMX-W300 Rear Case Replacement, Disconnect wire ribbon.: step 10, image 1 of 2 Samsung HMX-W300 Rear Case Replacement, Disconnect wire ribbon.: step 10, image 2 of 2
    • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
  11. Samsung HMX-W300 Rear Case Replacement, Remove screws.: step 11, image 1 of 3 Samsung HMX-W300 Rear Case Replacement, Remove screws.: step 11, image 2 of 3 Samsung HMX-W300 Rear Case Replacement, Remove screws.: step 11, image 3 of 3
    • Use Phillips size 00 and remove the 3 screws as shown.
  12. Samsung HMX-W300 Rear Case Replacement, Pry screen.: step 12, image 1 of 2 Samsung HMX-W300 Rear Case Replacement, Pry screen.: step 12, image 2 of 2
    • Pry the end of the screen with the plastic opening tool.
  13. Samsung HMX-W300 Rear Case Replacement: step 13, image 1 of 3 Samsung HMX-W300 Rear Case Replacement: step 13, image 2 of 3 Samsung HMX-W300 Rear Case Replacement: step 13, image 3 of 3
    • Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
  14. Samsung HMX-W300 Rear Case Replacement, Repalce rear case: step 14, image 1 of 1
    • Removal of the rear case is completed.
Robert
966 Reputation
8 Guides authored
USF Tampa, Team 9-2, Blackwell Winter 2015 Member of USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 277
