Introduction
The motherboard is the central component for your device and if it is damaged it will cause your device to most likely not function the way it should. This guide will help you replace the motherboard so that your device will have a completely new central system and be as good as new.
Insert a metal spudger between the back case and the screen of the device.
Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
Use a #000 Philips screwdriver to remove the three 2.8mm screws attaching the motherboard to the device.
2 other people completed this guide.
