Samsung Galaxy Tab 2 7.0 Speaker Replacement
  1. Samsung Galaxy Tab 2 7.0 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Speaker Replacement: step 2, image 1 of 2 Samsung Galaxy Tab 2 7.0 Speaker Replacement: step 2, image 2 of 2
    • Using a phillips head screwdriver, remove the two 4mm screws holding down each speaker.
  3. Samsung Galaxy Tab 2 7.0 Speaker Replacement: step 3, image 1 of 3 Samsung Galaxy Tab 2 7.0 Speaker Replacement: step 3, image 2 of 3 Samsung Galaxy Tab 2 7.0 Speaker Replacement: step 3, image 3 of 3
    • Locate the flex cable attaching each speaker to the motherboard.
    • Carefully use a nylon spudger to lift the cable and detach it from the motherboard.
    • Lift the speaker out of the device.
    • If the speaker does not come out easily, use a flat tool under the flex cable to slightly lift the speaker out of place before removing it with your hands.
    • Be careful when working with flex cables. Excessive force and sharp tools have the potential to damage these components.
Katija Tarailo
460 Reputation
3 Guides authored
IUPUI, Team S3-G1, Harley Spring 2017 Member of IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 747
