Samsung Galaxy S2 I9100 Screen Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Samsung Galaxy S2 I9100  Screen Replacement, Screen: step 1, image 1 of 1
    • Galaxy SII Screen Replacement Tutorial
  2. Samsung Galaxy S2 I9100  Screen Replacement: step 2, image 1 of 1
    • Remove battery door and battery
  3. Samsung Galaxy S2 I9100  Screen Replacement: step 3, image 1 of 1
    • Remove all screws on the back of the plastic frame
  4. Samsung Galaxy S2 I9100  Screen Replacement: step 4, image 1 of 1
    • Use a plastic tool to separate the rear frame from the front
  5. Samsung Galaxy S2 I9100  Screen Replacement: step 5, image 1 of 2 Samsung Galaxy S2 I9100  Screen Replacement: step 5, image 2 of 2
    • Now disconnect all connectors on the motherboard, making sure the front camera and buzzer. This is attached with the double-sided adhesive. As a precaution, remove the audio ear speaker. In all this we will always help with a plastic instrument and a spudger.
    • Remove with a thin tool "iSesamo" the volume rocker and power switch side, these are fixed with adhesive tape
  6. Samsung Galaxy S2 I9100  Screen Replacement: step 6, image 1 of 2 Samsung Galaxy S2 I9100  Screen Replacement: step 6, image 2 of 2
    • Now we can remove the logic board
  7. Samsung Galaxy S2 I9100  Screen Replacement: step 7, image 1 of 2 Samsung Galaxy S2 I9100  Screen Replacement: step 7, image 2 of 2
    • Remove the USB connector by unscrewing the two screws. Reinstall the new display starting from this step to number one on the procedure.
61 other people completed this guide.
AndreaBaglione
3,912 Reputation
3 Guides authored
One Comment
Hello AndreaBaglione,
We are iphone lcd dealer in China, and looking for original Iphone lcd, especially for 5G, both new and used accepted, quantity will be over 1000 and even more. Would you let me know whether you are doing this business or any channel that you can recommend? Thank you in advance. lihanshan@163.com
Best regards
Fiona
fiona - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 20
All Time: 8,474
