Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement
  1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: step 1, image 1 of 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: step 1, image 2 of 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: step 1, image 3 of 3
    • Hold down the power button until the device powers off
    • Close the device and flip it over
    • Remove the four rubber sockets near the corners of the device
    • Then remove the four 4.6 mm Phillips #00 screws
  2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: step 2, image 1 of 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: step 2, image 2 of 2
    • Use the metal spudger to pop the back off. Near the hinges is typically an easier place to start.
    • Continue along the edges until the back is completely detached.
  3. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: step 3, image 1 of 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: step 3, image 2 of 2
    • Locate the long grey box with the black band, which is labeled "Laptop Battery."
    • Remove the gray piece labeled "bracket battery BA61 - 03983A" located over the golden band connecting the battery and motherboard by unscrewing the two 4 mm Phillips #00 screws
  4. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: step 4, image 1 of 1
    • Unplug the golden band coming from the battery to the motherboard.
    • Using the Philips #000 remove the four 4mm screws holding the battery in place.
  5. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: step 5, image 1 of 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: step 5, image 2 of 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: step 5, image 3 of 3
    • Face hinges towards you
    • Pull out the white plug-in piece
    • Only remove the red and black wire from the wire guide
    • If the left speaker is broken, lift the black L-shaped piece called ">PC+ABS<S1-C(L) R0.0 BA96-07326A"
  6. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: step 6, image 1 of 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: step 6, image 2 of 3 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: step 6, image 3 of 3
    • Only remove the white and black wire from the wire guide
    • If the right speaker is broken, lift the black L-shaped piece called ">PC+ABS<S1-A(R) R0.0 BA96-07326B"
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 49
